Ahoy there,
I recently installed a pony carb on my stock 88.5 samurai 1.3 motor. Though it started and idels OK, it would not run well enough to even trust it to drive across town. I checked everything I could check externally last weekend and twiddled the idle mix screw. I bascially had to give up when darkness fell. I really dont have much chance to work on it during the week, either.
This afternoon I yanked it out and brought in inside. I spent an hour+ taking it apart and cleaning it out. It really looked fine inside, there was no obvious dirt or anything. A little black junk came out of one of the holes I squirted carb cleaner into, but it wasnt plugged and the stuff wasnt dirt (carbon maybe? Aside from now being certain that it was clean inside, I only did ONE thing different...
I changed the fuel inlet from the side-facing one to the rear-facing one and put the plug in the side facing one. In one of the things I read someone said to make sure you put it in the one with the large, open inlet, not the one with the small opening. They looked like they were around the same size to me, though the hole in one of them was a little off center. I held up the top of the carb and let the float droop, so as to open the fuel inlet. I squirted carb cleaner in each of the inlet holes to see which one flowed more freely and it was the one opposite where the inlet was installed previously.
So I dont really know if it was the cleaning or the switcheroo on the fuel inlet that cured the problem, but I put it back in, let it warm up and then set the idle mixture. I took a 5 mile ride up and down hills and on flat roads up to about 60 mph. I tried accelerating slowly and quickly, going around corners fast, downshifting and hammering it, lugging it below 2000 rpm, etc. I did everything I could think of to try and get it to stumble and it ran great through all of it.
The only thing I noticed was a very slight surging at constant throttle @ around 2500 rpms. I am thinking this might be a little vacuum leak someplace. I can spend some time cleaning up the truncated vac hoses and stuff now that it seems to be running right.
Many thank yous to all the folks who offered advice, suggestions and info during this process. Anyone who is abut to install this carb on their rig, please feel free to PM me and ask questions about my experience.
~daxe (zoom!)
~daxe (zoom!)
