Finally got a chance to work on my Pony swap tonight.
Got a couple of questions.
1.Where is the EGR?? I know i have to plug up 2 hoses or make a plate to plug it.
2.Mine is a canadian model so the fuel bowl little window goes to the front of the zuk right??
3.Do i take off the throttle return device or leave it there and modify my airbowl??
4."I used the closest vacuum port on the carb and ran a hose from it to the vacuum advance" Could someone explain where is the vacuum port on the carb and is the vacuum advance on the coil??
5.Do i use the stock spacer or the one i got with the pony carb,and since the stock gaskets stayed on and are in good condition can i use them again??
All and all everything went well tonight (which is very rare for me) got the pony cleaned up the best i could without opening it up.Dremmeled out the manifold found my 12 volt wire and got everything ready for tommorow night.
All thats left is to dremmel the spacer and plug hoses and gas return on carb.
Thanks for the help AGAIN And sorry for the stupid question's.
Steven
Steven
