Guest
·I just bought two 1989 Honda Pilots. I am having problems with one of
them when trying to change gear from neutral to forward or from neutral
to reverse. I always have to accelerate just a little bit in order for
the gear to engage.
Do you have any suggestions about the possible cause for this problem
and how I could fix it?
Also, there is a very tiny oil leak (about ten drops a day or so) on
the transmission gasket and I always have to make sure the oil level
is ok. Could I fix this small leak with some kind of oil additive? which
product would you recommend?
Thank you very much.
the gear to engage.
