Pictures?
830 Views 12 Replies 2 Participants Last post by  **DONOTDELETE**
Show me your pics. Is there any place I can pictures of different size lifts /wwwthreads_images/icons/tongue.gif ? Like I said, I want to get 33's but I don't know if I should get 3" or 4" lift with this /wwwthreads_images/icons/smile.gif . It's all preference but I don't have a gauge to make my decision from. /wwwthreads_images/icons/cool.gif
Thanks for the input, Jeff
'83 CJ7 258 i6 31x10.5 3in. lift?
See less See more
3
1 - 13 of 13 Posts
Mine has five inches of lift and I'm wearing 35 inch tires. I don't know if that will help you or not.
Jeep guy from Texas
attached is a picture of a '81 CJ-8 with a superlift 2" spring lift and a shackle reversal, (no body) and 32 x 11.5 BFG's on stock wheels. i'm sure 33's would fit, but rub while 4wheeling,
this link is to my wifes homepage it has more pictures, http://www.geocities.com/lorimaryrose/REPTAR.html
also i just remembered this CJ-8 has narrow track axle, your '83 has wide track, i'm sure that will make a difference.
3/4tonYJ
My Jeep Page
See less See more
I have 2 pics I can put up that may or may not help you out. The pic on this post is of a 77 CJ5 with add a leafs and 31 x 10.5 15 tires. The next post is of a 74 CJ5 with 4" springs and a 1/2" lift from shackles. Hope they help out a little.
See less See more
the 74
See less See more
I have an 84 CJ7. I had 4"superlift and 33's and they rubbed a lot in the woods. I added a body lift. Now I have 35's that rub a lot.
Take a look at http://members.aol.com/a4x4jeeper/
Brian "A4x4jeeper"
http://www.jerseywheelers.org/
If that is a 4 wheel drive hardware body on that cj5 of J.G.1.'s then there is also a 1.5 in. lift built into the tub. That is the same setup I run (total 6"lift) with 35x12.5 bfg mudds. Check my page for pics.
Al
http://My web page
No picture, but I can speak from experience. 33s will rub at full articulation with a 3" lift, you will need a 1" body lift. The usual setup is a 4" suspension lift. I run a 2.5" lift with a 1" body lift and 3/8" longer ConFerr shackles with 33s. They don't rub, miss by a hair up front. I've said this before, with a setup such as this, wheel offset is VERY important, if my tires stuck out 1/4" more they would catch the lip of the fender. Personally I like the slightly lower center of gravity, the trade off is rockcrawling and watching out for things like rocker panels.
Thanks for all the pics, great Jeeps. So, JerseyWheeler, you think if I put on a 3" lift w/ 1" body that 33's will rub off-road? Anyone out there with a plain 3" Superlift lift and 33's? Can I see a pic?
Thanks for all the info, Jeff /wwwthreads_images/icons/cool.gif
See less See more
80 CJ7 with 4" SkyJacker and 33x12.50x15 BFG Trail T/A. Well I can't get mine to attach, it says it's too big.
I had to make the file smaller, not as clear now, but I got it to work.
80 CJ7 with 4 inch lift, 33x12.50x15 Trail T/A
98 KX250
See less See more
2" Superlift, .5" lift from shackles, 1.5" bodylift (.5" built into glass tub). Suspension travel in the rear is limited by the shocks at the moment. Those are "narrow track axles". With your "wide track" axles you might get some rubbing. Go with the 4" suspension lift. I got the 2" springs real cheap which is why they are on there.
'79 CJ-7
See less See more
2
Hey Brad, if you're worried about the rocker panels, use the Currie rocker gaurds.
Gary
I'd love to get the Currie Rocker guards, but after spending about $1500 on parts in the last month, I'm tapped out. I'm going to make
my own out of angle iron.
1 - 13 of 13 Posts
