hey guys i really dont understand whats going on here, bronco 1995 EFI, the small air filter that goes to the crankcase (the end of the pcv line, from the oil cap to the air filter) well that small filter is getting really dirt whit oil, i have change it about 3 times this year, and its always the same, a lot of oil inside the air filter box, i check the pcv valve, it was a bit dirt, but i cleaned up, after i installed the valve i checked the pressure whit the engine on, it have a lot of negative pressure (vaccum) i installed a new small filter but its getting dirty again, check the pressure on the other side of the engine and theres almost none pressure, but i already checked out all the lines and theyre all clean, so what tha hell its going on here?...
