I am trying to hook up a friend, he is wiring up a 75 CJ5 and needs some instruction. He told me he had seen an article in JP mag covering it, Ive have most of the issues except a couple of the older ones. any teck links on this ?
jim
(JEEP LAW) 4 modifications per application
Thanks mark, I think it may help some but its a 75 that we are trying to wire. I wonder how much difference there is?
jim
Pre 76\'s are diferent
I rewired my 75 CJ5 a year ago. I wanted the Painless kit with the preterminated ends to make installation easier. I decided to change out the Dash, Steering Column, A new gas tank/sender/skid plate, sending units and Gauges at the same time, that way I wouldn't have to do any cutting of a brand new wiring harness.
Everything worked great (Keep in mind that there are always problems that you will run into) although the cost was more than I had originally planned for...it was worth it.
If I had the time, I would have opted for the custom do it yourself kit but I wanted to upgrade other parts of my Jeep that needed it too; so it all made sense to do it at the same time.
Here is what I ordered from 4WD Hardware:
Dashboard
Glove Box Plastic
Steering Column Cover
Wiring Harness (Heavy Duty)
Dash Lamp Kit (6 Lights)
Headlight Switch
Headlight Switch Knob
Windshield Wiper Switch
2 Speed Fan Switch
Switch Knob
Volt Gauge
Oil Sending Unit
Oil Gauge
Ignition Switch w/ Keys
Heater Air Cable 28"
Heater Temp Cable 21.5"
Heater Defrost Cable 21"
Fuel Sending unit Kit
Gas Tank & Skid Plate Kit
Steel Switch Nut
Aluminum Switch Spacer
Billet Aluminum Knob Set
14.5" 3 spoke Steering Wheel
Steering Wheel install Kit
Cost with shipping = $1,196.47
I also ordered a new steering column from Centech Wiring:
$234.95
For a grand total of $1,431.42
It wasn't cheap but it worked and now I have a 75 body and drivetrain with a 76 interior with tilt steering.
Check out my review of the Painless kit
Jay C.
I know what you're thinking. Did he fire six shots or only five?
