Well I'm sitting here and it's starting to hurt.
I think I pulled a muscle in my back today trying to get the pitman arm off.
It never came off, but.. so far..
We took about a 3 foot breaker to the nut with the correct size socket, and about 200+ lbs on the end of that started the socket off.. that... was the EASY part.
Next up, the puller. Stuck the puller on there, and ran it in. Put a 400 ftlbs impact on the back of that and it turned about 1 and a half turns. That was expected.
So we got out the breaker and couldn't find the appropriate socket for it, so we broke out the crecent wrenches and started heaving on that. THen put a pipe over it and heaved some more. It started moving.. but not in a good way.
We got it about 2 turns in, this is with about 5 foot of breaker bar on it, and 150 lbs or so.. (2 people pulling.)
What we started to notice, was that we'd get about 1/8th of a turn.. and the wrecnh was bending.. not the way you'd expect it though.. but the other way.. the HARD way to bend it.
Some more tugging and pushing resulted in the crecent end opening from 3/4" to about 1" and a broken ratchet wrench. (back to sears they go
The whole setup was on as far as it would go. and then it wouldn't come off.
Then we broke the puller.
So it's been dumped in more penetrating juice.. and I'll give it a go on thursday..
Then I get to find out if the ZJ arm that I bought for 4" drop is going to work.
