Guest
·Lost a good weekend jeeping in Tellico because my ride overheated going to the trails. I had experienced this a few months back but thought I had taken the necessary corrective action. On that occasion the I6-258 w/MPI overheating while idleing down the trail, no problem while running at hwy speed. Changed the thermostat, coolant and radiator cap added fan shroud. No problem driving around town for 2 months.....trailer it to Tellico 500 miles....and it over heats going to the registration gate. I pulled the thermostat completely added water/coolant mix and ran to trail head hoping it was a bad thermostat. Nope...still over heated. Rode shotgun all weekend, pulled wench cable and lent a hand fixing others rigs.
Suggestions as to the problem: Timeing is off? Distributor is bad? Radiator is blocked? Water pump is gone? Head gasket is leaking engine pressure into coolant system preventing proper coolant flow? My shade tree mechanic thinks my catalytic convertor is disintegrating and causing sporatic blockage. He is ready to punch out the remainder and run it open.
what do you all think?
-Will
-Will
