Hopefully someone here has an idea of why my little 225 overheats within 10 minutes of driving in cool, low altitude temps.
This motor is in my little willys MB I built over the summer, it came from a 69 Jeepster and did not overheat in it. I have a new 3 row crossflow radiator with a huge 19x22" core, a huge hayden electric puller fan that will suck in a piece of paper flat to the grill from a foot away, new hoses, a new 160 degree thermostat, and for the moment until I can fix this problem I an running just water, no antifreeze. It overheats just driving the 7 miles or so to school on a cold morning at fairly low rpm's (2000 or so). The distributor is a stock delco, timing is 5 degrees at idle, all stock ignition, all stock motor from what I know, new carb, and the mixture seems to be a bit rich by looking at the #1 plug. It was running lean, and I thought that was the problem, so I drilled out the jets just a hair. The motor has plenty of power, both rear tires will break loose with a tap of the throttle, real fun with no windshield, seatbelts, turn signals, brains, etc.....
I was thinking bubble in the cooling system, but I have not the slightest idea on getting it out, I have let it idle and warm up the with the cap off (new 16 pounder) and have been checking coolant very frequently. I added a coolant return system as well. Any ideas??
