Guest
·Hey all,
as i was sliding out my axles to install my locker, i noticed the wheel bearing was cracked. so i totally removed the axle to replace the bearing. i noticed my Moser Axle has no outer seal. is this correct? or did the previous owner/installer of my jeep not install them correctly? they dont leak, so apparently it is ok. i just found this odd. do you all have outer seals on your Moser one peice axles? thanks!
JUSTIN
http://www.geocities.com/jeepboyjus
83 CJ7 258 T5/D300 4"lift locked AMC20 1pc axles 3.54
JUSTIN
