My 89 XJ with a 4.0L will not idle right. Replaced IAC, but when I start it RPM's will shoot up to around 2000. Does not do it all the time. Can IAC be adjusted? Any other suggestions? Very angering!!!
It probably is the TPS but I had the same problem on a Subaru I have. It was the "throttle kick" from the AC. I had disconnected the AC compressor for winter to keep it from coming on and it thew the computer into a frenzy. In park and Neutral it would rev to about 2500 to 3000 RPM's. It's a long shot but another route you can look at.
I would check the vacum lines off of the throttle body especially if you bought it used , people like to plug things thinking they know what they are doing.
I did find a vacume problem on the t-body. As you face the engine on the left side of the t-body there are 2 v-lines. the lower one had a line. However, the upper was plugged witha screw. I can't find a vacum diagram anyplace. Any Idea what was supposed to go there?
The a/c is unhooked right now. But, when in drive it does the same thing. If I dont hold the brake it will speed up to aroud 20mph on its own. thanks anyways.
Freedom is not Free! Support our tropps and President
