I'm having a problem with my old 1990 S-10 Chevrolet, it has a 4.3 engine. I bought this truck new, and after 242,000 miles, I've been noticing a strange viberation.
It's most noticable at about 2000 to 2500 rpms, but it seems to be there even somewhat at idling. It viberates, or shakes, or pulsates, or whatever you'd like to call it, for just about 1.5 seconds, then it smooths out for a couple of seconds, then it repeats this process again, and again???
I changed the spark plugs, and found one that looked as if hadn't been firing good, I also went ahead, and replaced the spark plug wires, distributor cap, rotor button, and PCV valve, just for good measure.
Everything I done so far has helped the viberation, but has not eliminated it. I'm considering changing the coil, though it's almost $50.00,
but I'm not sure that'll cure the problem. I'm also starting to question the throttle-body fuel injection???
Some of you may wonder, why I started with the ignition system first, well to be honest, the plugs had not been changed in about 3 or 4 years, and the wires, distributor cap, and rotor button, were original-almost 14 years old!!!
The coil is also the original one, I know, I know your thinking, I must not take very good care of my vehichles.
Actually, I just never had any trouble, until now, you know the old saying, "If it ain't broke, don't fix it." The only problem with that is after 242,000 miles, almost anything could be broke.
I sure could use some advice here, please try to refrain from being cruel,
as tempting as it may be.
Thanks,
Thanks,
