I’m thinking about installing a supplementary fuel tank in a pickup. I’ve looked at the aftermarket ones available, and they all replace the spare tire and cost an arm and a leg. I can go to the truck parts store and get a nice 50 gallon steel or aluminum fuel tank for maybe $40 and do the same thing myself, I’m thinking. Instead of permanently installing the tank, I’m considering just mounting it in the bed when I need it (when I’m going on a long trip, etc.) I can figure out secure ways to mount it, but here are my questions.
1. If the truck has a cap on it, and I vent the tank to outside the cap, does anyone see a problem with vapor buildup inside the cap?
2. My thought is to use the aux. tank as a fill-up tank for the std. tank. By that, I mean I’m considering just running a line from the aux tank to the main tank and using it to fill the main tank, instead of duplicating all the fuel lines and using the aux tank separately. Any problems with that thought?
2a. How do I plumb the line from the aux. tank into the main tank reservoir?
2b. If the aux tank is in the bed, above the main tank, can I just run a valve on the aux tank to close it, and open it and let it gravity fill the main tank? Or should I run a small electric fuel pump to transfer the fuel? What would work good for a valve and/or pump? I’d like to use electrically controlled ones so I can ‘refuel myself on the go.’
3. What am I not thinking of? I know the tank will need to be grounded…and I know I’ll need to figure out a way to fill the tank easily if I put it under a cap. The cap isn’t on all the time, but generally, when doing a road trip, I do use it so I have some more storage space. Is there a better suggestion or solution to the problem that I haven’t considered? (I know I could use gas cans or jerry cans…)
4. Is the refueling on the go thing too much of a hassle? Should I just build a system that uses a standard transfer tank and just pull over and refuel myself in the standard fashion?
I Jeep, therefore I am.
