Well the welder is progressing although, I think I just voided the warranty! /wwwthreads_images/icons/smile.gif I've bypassed the regulator by wiring a 10 gage wire directly to the field brush. The exciter diode is also removed. So now in theory the rotor should get the full 12V without regulation and the output woltage can increase relative to the RPM. I've connected my battery charger on the manual 2A setting, positive to the field, negative to ground on case. Then I connected my multi meter to the positive output and negative ground on case. I spun the rotor with my electric drill at about 400 RPM and measured around 5-6 volts. Somehow, I expected more but we'll see. I don't know if the voltage suppose to increase in a linear fashion or maybe logaritmically. Now I'm onto fabbing a bracket to mount it. That looks to be more of a challenge! /wwwthreads_images/icons/crazy.gif Anyway, it's progress. /wwwthreads_images/icons/smile.gif
The picures:
http://www.webphotos.com/member/7612/143804.jpg
http://www.webphotos.com/member/7612/143805.jpg
'91 YJ,I-6,2.5" lift,Boomerangs,33s,D30,D35c,Lock-Rights F&R
The picures:
