/wwwthreads_images/icons/tongue.gif Here is the reality of this trick, guys; and for you too, Jeepchicks. Mechanical tube shapes like square tube and rectangular tube are made to be just that.....MECHANICAL tubing...not pressure vessels. The weld is not really made for that kind of separating force, and there is no testing done because of that. This is simply playing Russian Roulette....either it will hold, or it will blow and well..../wwwthreads_images/icons/frown.gif It's a calculated risk. A heavy wall tube would offer slightly increased protection, but the key word here is "slightly". Didja ever wonder why so many air compressor tanks have those two plugs on the side of the tanks near the ends that nobody ever seems to have any use for? Well, those are INSPECTION holes for the IN-SPECT-TORE to look in there and see how the shell is welded to the tank ends. And didja ever wonder why tanks are always curved on the ends? That is because if you use flat plate, the pressure can bend it outward and begin separating the weld. Heavy pressure tanks always use a tank end which is like a BBQ....curved with sides which mate to the tank shell with a butt weld. That is so the separating forces will pull the weld, not get a lever on it and bend it. Go to a diesel truck wrecking yard or an air compressor place and look for a genuine pressure-capable tank. All of us on the BBS would just hate to hear about a terrible Jeep accident involving an air tank, like the incident in AZ where the guys were using one of those US Navy surplus round buoys for a water pressure tank, and when the pump pressure reached 75 the top ripped off and killed one guy's teenage son who was standing right there./wwwthreads_images/icons/frown.gifBelieve me, I've been Joe Junkyard most of my life, but I have a healthy respect for high pressure air in a confined space. Does the term "bomb" bring anything to mind?/wwwthreads_images/icons/crazy.gif
