1 - 8 of 8 Posts
my tj at idle sits at 19 to 22 psi and when i am on the freeway doing 60 or so it will sit at 40. is my oil pump going or am i ok. the motor has about 150,000 miles. i am only asking because on my other tj with the 4 cylinder always idled at 40 psi and went to 60 on the freeway.
Mine runs in the low 50's at cold idle. Once it gets good and warmed up, it will idle at about 25-28.
At 2K RPM on the road it runs in the low to mid 50's.
It's a '99 with about 58K miles on it.
I just added a mechanical pressure gauge a few weeks ago after my second sending unit took a dump on me in about 6 months. They're known to be crap on TJ's. But, when they go bad they'll jump all over the place, not just run below where they ought to be.
I know this doesn't answer your question, but a little info for you to use as you see fit.
HTH
You're fine, Specs for a 2003 4.0 say 13psi at idle and 37 to 75 psi @ 1600 and higher. I don't have my other FSM's handy but suspect the specs are the same. Electric oil pressure gauges give approximate readings, put a manual gauge on it if you're still concerned about it.
My 97 XJ 4.0 Auto,,,runs the same as yours. this week passed 149,000 miles and runs like a champ.
[ QUOTE ]
[/ QUOTE ]
My 93 XJ 4.0 Auto, is about the same, 249,000+ and going strong. Gotta love it!
Those figures are about what my 99 had with the stock oil pump. I put a high volume in ..and I don't think it was really necessary. The 75 limit is to limit the stress on the shaft. In a 4.0 (or any other pushrod engine) the oil volume and the relief limit don't have to have anything to do with each other.
If you want more oil pressure, go to a 5w-40 synth. It will give you a higher pressure then a multi-visc 30 weight without as much start up parasitic losses associated with a conventional 40 weight. Something like Rotella T synth is good for about 10k or a year (make it 6 months for extreme duty) ...maybe more :shrug:
The only thing going is probably the oil pressure sensor...
ive always gone by the old..."10PSI per 1000 RPM" rule, so far ive never blown a motor/ubbthreads/images/graemlins/grin.gif
1 - 8 of 8 Posts
