There is a seal in the timing chain cover. You access it from the inside of the cover (sounds like this is an unfortunate fact if you are ready to reinstall). It is a rope type seal that is held in place by a retainer ring, similar to a "real" seal.
Oh yeah, this thing seals on the Harmonic Balancer, NOT the crankshaft. If the balancer is not on yet, oil will run out even if the seal is good.
If the seal does not hold oil with the balancer installed, I would replace it. With the timing chain cover removed, you can knock the retainer out with a punch and hammer (careful not to damage it, only takes a few light taps). Remove & replace the rope seal and reinstall the cover. This operation will require a timing chain gasket kit and the removal of fuel pump, distributor, radiator hoses, alternator, p/s if any and the front two oil pan bolts. If you are careful, the oil pan gasket will remain in place and you can seal with some sealant when replacing the timing chain cover. (Just did this on Ole Yeller with my son.)
Good Luck, Brad.
Re: oil behind the harmonic balancer
they(seal manufactures) make a replacement seal that is rubber. that is better way to go.
Yeah, heard that there is also a rubber rear main seal instead of the rope two piece. The gasket kits we ordered had the rope seals in them though and Chris was in a hurry to get it back together, so I used them.
Any idea of part numbers?
Brad.
