Re: Oh yeah, that\'s it!
Depends on your lift kit. Did you install a 4" lift? Transfer case drop? CV driveshaft? What size tires? If you take the bump stop extenders out, one or more of a bunch of things can happen. You could hit the sheetmetal with your tire, try to shorten your driveshaft too much with the flex and slam it into the transfer case(bad results), get limited travel anyway when your highly arched spring tries to flatten out that much and the shackle travel stops your articulation, bottom out your shock absorbers......
travel and articulation are functions of all of these things. Investigate all these things to get your best articulation without damage or limitation.
Good luck
Pete
Good luck
Pete
