Ive been having a lot of transmission trouble lately and I may have found a decent NP435.
Im trying to find out what Ill need in addition to the transfer case adaptor.
I know I may have to get new driveshafts because of the difference in transmission lengths.
What about the clutch pressure plate and disc? Will the stock disc work? The novak tech site didn't really go into this.
NP435 input shaft is 1 1/16in ten spline and sticks out 6.5in.
T-5 input shaft 1 1/8in ten spline and sticks out 7.5 in.
That seems like a big difference in input shafts but I couldnt find anything saying I'd need adaptors or a new clutch assembly.
Thanks.
You'll need a different input shaft. It's got to engage the pilot bushing, and if it's an inch shorter, it won't just won't reach. /ubbthreads/images/graemlins/frown.gif And the 1/16" difference in spline diameter won't work with the stock friction disk.
If there is a shaft that will work, Novak should have it. If you can't find it on their website, call them.
I don't have the part numbers handy, but i have done this conversion. I think I posted the info here a long time ago. I'll try to find my notes.
Anyway on a YJ I used.
The 6.5" stickout ford np435,
A T-150/176 bellhousing
A stock hydraulic slave cylinder (possibly from a jeep with the Pontiac "Iron Duke"
CJ master cylinder
starter used by the T-150/176 trans,
special pilot bushing (available from Novak or AA),
AA Np435 to NP231 adaptor
in my combo, the pressure plate is either the correct one for the T-150/176 trans or an '88 yj with a 4.2 and 5 speed. Not sure.
i think the clutch disc is a mustang or CJ. Anyway it is a simple matter of matching the needed outside diameter and spline count and sizes.
In My YJ, the skid plate had to be modified and I am not sure this swap could be done without a bobylift of floor mods.
Also if anyone reading this is considering this swap into a YJ, it is my understanding that all YJ 4.2's actually used the same flywheels as the early non HO 4.0. Mine did. the problem here is that the 4.0 flywheel is thinner (from the crank flange to flywheel face) than the 4.2 flywheels from CJ's. This caused me problems with the clutch not releasing. Swapping to the thicker "CJ years" flywheel solves this problem.
