I know the 3" body lift and 4" susp isn't helping the linkage but it seems like sometimes it just doesn't want to go into 4L! And when it does, it is a PITA to get back out. I have to put it in drive and neutral a few times and then a simple tug on the shift does the trick. Worse case I get up under the jeep with a BF Bar and try to pry the lever on the 231 into the correct position! My shifters bracket is custom since my TH350 adapter sits where the stock stuff bolts up, I may try tightening up the linkage next time I have the skid plate off.
Does anyone else have this problem? Any tricks to getting into 4L. Can the nut holding the lever to the 231 get too tight causing it to bind up?
'88 YJ, 4" susp,3" body,35's,283 Chevy V8,TH350,4.11's,D30,D35c
