Diode Dynamics is excited to announce our new Bumper LED Light Bar Bracket Kit for the 2018 Jeep JL Wrangler! Our engineers have designed steel, powdercoated brackets that enable up to two (2) 30" Stage Series LED Light Bars to be easily mounted onto the JL Wrangler's front bumper using factory mounting points for dramatically improved visibility. No cutting or drilling required! These LED light bar brackets are compatible with all trim levels of the 2018+ JL Wrangler, including the Sport, Sport S, Sahara, and Rubicon.
This LED light bar bracket kit can be mounted in three different ways. Mount a single 30" light bar using the base brackets, or use the included extension brackets to allow clearance for a winch or other accessory, or mount a second light bar for maximum light output! Additionally, the brackets can be purchased separately, and are compatible with any generic 30" LED light bar. Each kit includes:
-Base brackets
-Extension brackets
-Hardware
-One (1) or Two (2) Stage Series 30" LED Light Bars
-OEM Auxiliary Switch Dual Output Harness
-Heavy Duty Dual Output Light Bar Wiring Harness
-Installation guide
Also included with the kit is Diode Dynamics new OEM Auxiliary Switch Dual-Output Wiring Harness. This harness enables Jeep JL Wrangler owners to control the LED light bars using the factory-installed auxiliary switch bank! For those who don't have the aux switch bank, our Heavy Duty Dual-Output Wiring Harness is also included to mount a switch and connect directly to the battery.
The Stage Series LED Light Bars featured in this kit utilize our exlusive Total Internal Reflection or TIR optics to produce an extremely bright, functional beam pattern. Unlike cheap LED light bars that throw lots of unwanted glare, Stage Series Light Bars have been engineered from the ground-up to provide focused, usable light. Thanks to their efficency, the Stage Series LED Light Bars are much lighter and more compact while still being extremely bright, making them the best LED light bars for the Jeep JL Wrangler.
These kits are 100% designed and tested in the U.S.A, and are backed by Diode Dynamics 3-year worry-free warranty! Want to check out more LED lighting upgrades for your 2018+ Jeep JL Wrangler? Click here to see all our LED upgrades for the JL Wrangler!
If you have any questions, please don't hesitate to post, PM, email [email protected] or call us: (314) 205-3033
Jake H.
Diode Dynamics
