This forum gets very little traffic so i have been lax in posting. This might get your fix. It is my street legal Chenowith rail that I have owned for 20 years. I have the whole history/build posted on Woddsbuggy.com and shoptalklforums.com under perrib. It gets a lot of use all year long.
New cross bracing for the new beam and rack.
Welded in braces for the switch from swing to Bus IRS. I took it out for a test drive without these and the there was enough flex to pull the coil wire out of the coil.
Backside of the Rolls
Porter Mountain Lake Side Az
Stock spindles did not agree with the new 33x9.50 tires.
One of the earliest pictures of it. Note the tiedowns holding the fuel tank that fell off and was lost for 8 hours.
Stuck in quick sand at Mesquite Creek
Up on the rack in Crown King Az
Running 12.1 at Fire Bird Drag Strip in the early 90s.
A peek under her skirt. Firemans Hill Upper Sycamore Creek.
[Most of the videos are on You Tube under VW2180 but here are some others that would not load on You Tube.
Sycamore Upper 1 29 2007 :: Sycamore 1 29 2009 video by perrib - Photobucket
Sycamore Upper 1 29 2007 :: Sycamorecreek1312009024.flv video by perrib - Photobucket
sycamore 1 2 2009 :: Sycamoe 1/2/09 video by perrib - Photobucket
