This is going to get long.
I have a freshly rebuilt engine AMC 360. I have less that 10 hours total time on the engine. I've only driven it about 2 miles, and that went fine. I was working on a issue concerning the throttle linkage. I had put a 4 barrel dual plane Edelbrock intake and Carter AFB carb on during the rebuilt. I had to replace the stock throttle linkage to get better control. That was what I was one of things I was doing today when the knocking started. Earlier today I added a mechnical temp. guage. I didn't trust the factory gauge. Prior to this the engine appeared to be running good, especially considering this was my first rebuild. It does not sound like a rod knock. It sounds more like the upper engine. I shut down the engine as fast as I could when the noise started.
Here's what went into the engine:
A Federal Mogul Premium engine kit- this includes new lifters, pushrods, cam, pistons, oil pump gear, bearings (piston, rod and cam) and rings. I went with chromoly rings. I added a new oil pump pickup and replaced 8 of the rocker arm pivots. Those eight appeared to be worn badly.
I had the block worked over. vatted, cleaned, bored. The alignment of the crank shaft bore was checked. I had the machine shop handle the cam bearing and pressing the pistons on the rods. I also had the heads reworked.
More background: I checked all the bearing clearences and they were within specs. I was making 60 pounds of oil pressure at cold idle, 20 + pounds at hot idle. The pressure maintained fine the few times I drove it. I had not checked the oil pressure today. I had just started the engine and was letting it warm up as I watched the temp readings. I installed the temp sending unit but didn't mount the thing into the dash. I left the temp guage dail setting in the engine compartment so I could watch it, and check for any coolant leaks.
After the noise first started, I shut it down. Since the noise sounded like the upper end, I pulled the valve cover. I found one of the new rocker arm pivots had cracked. I went to the parts store and got a new rocker arm set. I checked the pushrods, they were not bent. I then installed the 2 new pivots and the rocker arm bridge. I did a compression test on that cylinder. It was reading @ 150 #'s. The valves appeared to open and close properly. The engine turned over fine, no noise. Drained the oil and replaced the oil filter. I did not see anything in the oil, nor did I appear to loose any coolant. It did not appear that I had exhaust gasses coming back into cooling system. I did not appear to have any gas in the oil.
I started the engine again and the noise was still there. I shut it down before I even took my hand off the key from when it started. I drained the oil again and dropped the oil pan. There was nothing sitting in the bottom of the pan, and the oil still looked brand new. I was looking for loose rod bolts or main bearing caps. The noise appeared to come from the front of the engine, which was were the broken pivot was. I looked at the front four rod caps, all of them looked fine. I pulled the plugs and watched the bottom of the engine as I turned it over with a breaker bar on the crankshaft. I pulled the front main cap. The bearing looked good. I thought it might have been spun. I haven't checked any of the other bearings to see if they had spun.
I stopped doing anything else because I really did not know what to do, or what to look for.
My previous engine had a bad cylinder, with 60 #'s of compression. I could hear the rod knocking in that cylinder. It was a different sound than the sound in the new engine. I lost my access to the shop that I installed and rebuilt the engine in. At least for a long while. So I need to try and diagnose the problem before pulling the engine.
What diagnostics can I do? Pull the rod caps? Pull the rest of the main caps bearings? Pull them using a use a torque wrench to see if they worked out of torque spec? If I check the compression on all of the cylinders, that would eliminate a cam lobe/lifter problem?
My speculation is that it is a loose wrist pin. I don't know how to tell if one is loose. I suspect that would mean pulling the heads to check the questionable piston.
Thanks for any suggestions-Brett
