Hi All,
I just purchased a 2005 Kasea Skyhawk mini50 for my young boy. I would like to change the oil and I've been searching this forum but I can not find the recommended oil. When I drained it out it looked like ATF Fluid, red in color.
On the case is stamped "OIL 100CM3" so I'm assuming it will need 100 cubic centimeters to fill. Does it really only use 3.4oz of oil?
Anyone know the proper fluid to use when I refill?
Also, are there any links to a service manual that I could download?
Many Thanks,
Howard
So I was digging around in my garage and I found some Honda Hi-Performance Transmission Oil SAE80W/85W... is this in spec to use in the CVT transmission???
Thanks,
Howard
