You didn't say how the bike ran. Fuel/oil ratio, type of oil. Personal preference in oil is important, find one you trust and stay with it, don't change two stroke too often, imcompatability between oils can cause bottom end failure. My preference is sprctro @ 40:1. If your bike is fouling plugs but running ok, you might need to go to a hotter plug, but again, be careful, wide open with too hot a plug spells hole in the piston (hitp). Most of the time, raising the clip on the needle one notch and going one step leaner on the pilot will give you substantial results. Watch out for pinging. Bad....Is your plug black when you take it out?? Lots of variables, the main thing is to not be too drastic in the solution, or you might end up with bigger problems. There are some very good articles out there on jetting if you can find them. Good luck
JDDick
