My CJ has 2.73 gears. Before I did the HEI conversion my CJ would stall unless I slipped the clutch. Now it drives much better and I am considering the Teralow(4to1) kit for my Dana 300. Is this a cheaper easier way to increase my crawl ratio. The lowest gears I would consider are 4.10s. If I swap gears I increase my crawl ratio by 1.5 times. If I do the Teralow my low range ratio increases by 1.53 times. I basically get the same result for less money with the Teralow. Are my calculations correct, does it make sense to do the Teralow if I am happy with how my Jeep performs in 2HI?
Thanks,
85 CJ7-4.2L,T-176,D300,2.5"lift,32"BFG MT,Durabak,York-Air,HEI
Thanks,
