· Vendor
Looking to upgrade the tail lights on your Toyota Tacoma? Look no further. Introducing Sequential LED Tail Lights from Form Lighting. Not only will you stand out on the road with a more modern appearance, but you’ll add LED reverse lights, a sequential LED turn signal, and a unique startup sequence.
Modern Appearance. Unlike many other aftermarket options on the market, these tail lights were designed with factory-style optics, to diffuse the light in a smooth, even appearance. The outer perimeter of the lamps illuminates in a C-shaped bar for running and brake/turn lights. On the interior of the lamp, you’ll find a unique 4-tier LED design, for a truly distinct and premium look.
Smoked, Not Sprayed. Nightshade? No thanks. The lens on our Tacoma tail lamp is designed with tinted optical components, which provides a factory-quality smoked appearance - not a cheap painted look like others on the market.
Startup Sequence. These tail lights are packed with modern features, including a unique startup animation. Anytime the running light turns on, it will illuminate in a chasing stacking pattern that is sure to turn heads.
Sequential Turn Signal. The startup sequence won’t be the only thing turning heads. These tail lights also feature a sequential LED turn signal. Any time the turn signal is activated, the red LEDs in the outer C-bar smoothly sequence from the top and bottom, meeting in the middle for a truly premium look.
OEM-Grade Construction. Form Lighting tail lights are built with quality in mind and constructed using OEM-grade materials, including a UV-coated polycarbonate lens, automotive-grade LEDs and optics, and direct-fit connectors. While they may not be the cheapest option on the market, the fit and finish of our lamps are superior to other aftermarket units.
Road Legal. The smoked lens color illuminates with red LEDs, and features an integrated retroreflector sidemarker and running light, just like the factory lamp. These lamps are SAE and DOT-compliant for on-road use.
Plug-and-Play. Our tail lights for the Tacoma are plug-and-play. They will fit perfectly, without any body gaps. Installation is a breeze and can be done in under 10 minutes. Unlike other options on the market, these tail lights are also fully compatible with Tacoma’s blind spot detection system, if you have it. There are no blind spot system errors, flickering, or hyperflashing!
Click the video below to see HOW to install our 2016-2023 Toyota Tacoma Sequential LED Tail Lights!
Two-Year Warranty. All Form Lighting products are rigorously tested for reliability, and backed by a two-year warranty. The warranty is supported directly by Form Lighting, and any replacement parts, if needed, are shipped quickly from Form Lighting’s US warehouse. On the rare occasion that you may need to utilize your warranty, we try to keep the process as simple as possible - for example, no return usually is necessary.
Do you have additional questions? We’ll be happy to help!
• Reply to this thread
• Send us a direct message
• Email: [email protected]
Are you a US forum member? DM us for a FREE shipping code!
Jordan M.
FORM Lighting
· Vendor
ONE. MORE. SALE. 🏷
Now through 1/5, you can get 15% OFF all FORM Lighting products exclusively through Amazon and our authorized dealers.
This sale includes our new LED tail lights for the 16-23 Tacoma, which just started shipping this week!
Shop our Amazon store ➡ Form Lighting
· Vendor
There’s only a few days left to save!
Through midnight 1/5, you can get 15% OFF all FORM Lighting products exclusively through Amazon and our authorized dealers.
This sale even includes our new tail lights for the 16+ Tacoma!
