Form Lighting is excited to introduce our Sequential LED Headlights for the 2016-2023 Toyota Tacoma!
Our Sequential LED Headlights are the perfect way to upgrade your 2016-2023 Tacoma. With these premium OE-grade replacements, you’ll add triple bi-LED projectors, sequential turn signals, startup sequence, LED running light, and a more aggressive, modern appearance.
Triple Projectors. What’s better than one projector? Three projectors. And in these headlights, all three are bi-LED units, providing output for both low beam and high beam illumination. With a sharp cutoff, broad width, and high intensity, these units provide a serious upgrade in output.
Startup Sequence. These headlights are packed with the latest and most modern lighting functions, including a startup or “welcome” sequence. Anytime the running lights turn on, they will illuminate in a two-stage chasing sequence that is sure to turn heads, with an ultra-premium look.
Sequential Turn Signal. The startup sequence isn’t the only thing that stands out. These headlights also feature a sequential switchback LED turn signal. Every time the turn signal is activated, amber LEDs activate across the top of the running light in a smooth, chasing sequence. When you’re finished making your turn, they automatically “switch back” to the bright white DRL.
OEM-Grade Construction. Form Lighting headlights are built with quality in mind, using OE-grade materials and design techniques. This includes durable UV-coated polycarbonate lenses, automotive-grade LED emitters, breather vents, and OEM plug-and-play connectors. You can rest assured that these lights will provide durable and superior performance.
Road Legal. Form Lighting headlights meet all SAE, DOT, FMVSS, and CMVSS standards and regulations for legal on-road use in the United States and Canada, when installed and aimed properly - which is easy to do with the integrated screw-type adjusters.
Plug-and-Play. Our headlights for the Tacoma are completely plug-and play and will fit perfectly, without any gaps. They were designed to plug into your factory headlight connector, with no wiring modifications needed. No errors, flickering, or hyperflashing! Adapters are also included to power the running lights, if your truck doesn’t come with daytime running lights (non-DTRL) from the factory.
Click the video below to see HOW to install our 2016-2023 Toyota Tacoma Sequential LED Headlights!
Two-Year Warranty. All Form Lighting products are rigorously tested for reliability, and backed by a two-year warranty. The warranty is supported directly by Form Lighting, and any replacement parts, if needed, are shipped quickly from Form Lighting’s US warehouse. In the rare occasion that you may need to utilize your warranty, we try to keep the process as simple as possible - for example, no return is normally necessary.
Click HERE to check out our 2016-2023 Toyota Tacoma Sequential LED Headlights!
Do you have additional questions? We’ll be happy to help!
• Reply to this thread
• Send us a direct message
• Email: [email protected]
Are you a US forum member? DM us for a FREE shipping code!
Jordan M.
Form Lighting
