Hello. I just installed a B&M Truck Megashifter in my 83 Jimmy. I was just wondering if anyone knows where the wires are that i have to splice into for the neutral safety switch and the back up lights and how do you best go about wiring them up? All it says in the instructions is splice the switches in. Any help would be great. Thank you.
There is a white plastic piece on your steering shaft, close to where it goes through the firewall. It adjusts left and right and has some wires coming from it.
I'm not sure which wire does what, but that piece is for the back-up lights.
ok thanks ill check that out im sure once i locate the switches i will be able to figure it out. How bout that neutral safety switch? Any clue ? I normally wouldn't care about that but i just moved to this province and they require a safety certification check(again blah)to register my vehicle here. So......
