1 - 9 of 9 Posts
I do not know the proper name for the thing I broke. iIt is the arm on top of the clutch petal that the clutch cable hooks on. It is under the dash in the truck, not dwon at the clutch. Please help me with the proper name for it. I need to replace it, so if you have one let me know. I can't stand for my zuke to be down. Pleasae Help
You will probably need a new clutch and brake pedal assembly. A friend of mine broke his too, we welded it back, and it held for a little bit, but broke again. I would not recommend welding, just get the new assembly. just my .02 , hope it helps.
btw, I searched ebay and didnt see anything. good luck!
The part that broke just slides over the shaft and clamps in place with a bolt. It split on the side. I hope I don't have to purchase the entire assembly for this little arm.
I don't know the proper name of it but i have broken a couple myelf. usually the reason it break is because the cable is binding up in the housing. so check that the cable moves freely befor just replacing the bracket
Mine did the same thing.
I repaired the old for a spair.
I thought my Clutch cable was ok.
But after talking to TT I went ahead a replaced it.
It made quite a bit of differance.
Especialy if you look at the gauge of that part.
It is made from thin material.
1 - 9 of 9 Posts
