Need source for good/cheap thumb screw hardware
2K views 13 replies 8 participants last post by  bluseman2a
Hey all,
I'm in the process of finishing a really killer overhead console and I need the perfect hardware to bolt it to up onto the cage. I wanted to get some knurled head thumbscrews for easy access in case of repairs or such.
For most of the panels, I'm using stainless buttonhead allen bolts. I'm limited to 1/4" 20 (probably 1/2" long) hardware since I've already tack-welded the nuts to the rails. On the hinged "access" panel is where I wanted to use these.
I've tried McMaster-Carr and the ones I REALLY wanted were friggin' $3.50, EACH!!! Since I need 10 or more (depends on how fancy I wanna get) I can't see paying $35 for BOLTS.
http://www.mcmaster.com/param/asp/psearch.asp?FAM=thumb&FT_113=11123&FT_110=378&FT_123=447&FT_103=191&FT_101=11136&session=thumb;113=11123;110=378;123=447;103=191;101=11136
If you can recommend a source where I can find this kind of thing cheaper, I would be GREATLY appreciative. I've tried EVERYwhere I know of, Ace, the GOOD hardware store, etc. Bonus points for Atlanta locations.
Here are some that I came up with as an alternate, they remind me of the knobs on the sides of CB's. They'll work, but won't look anywhere NEAR as cool.
http://www.mcmaster.com/param/asp/psearch.asp?FAM=thumb&FT_113=11121&FT_110=11110&FT_123
'83 CJ-7 nothing original but the tub and axle tubes
I know you said you tried an Ace but, I worked at one for 5 years. As long as you don't mind having a recess for an allen wrench in the head, they should have what you want. Although they are all independantly owned so you never know. My store dealt with Midwest Fasteners for out nuts and bolts. BUt I have seen other Ace's that dealt with Hillman that should also have what you want.
"Every form of refuge has it's price."
#3 ·
bluesman, I found some thumb screws at my local computer store that would work great. They are brass or at least gold colored. and were about .35 a piece. they are sold as replacements for the screws that hold the cover on your computer.
Craig
84 CJ7
BRC Lifetime Member
#6 ·
Ok everybody, pay attention now.
Go to www.mscdirect.com and become a customer. It is a wonderful company to do business with. Their prices are usually the best I can find, the service is excellent, and they have damn near everything! Their catalog is a hardbound book that must weigh over five pounds. They have a huge inventory in several places in the eastern half of the country, and if you call by early afternoon, almost everything in the catalog can be in your hands the next day. They are aimed primarily at businesses, but are always looking to expand.
Get hooked up with them. You'll thank me.
Jim
#10 ·
Bluesman,....... fancy....,. don't make it too easy to steal...../wwwthreads_images/icons/smile.gif
1/4 X 20 is the standard size for woodworking jigs. I'd try any of the numerous woodworking stores in your area. There is any thing you want for a knob shape.
http:// www.leevalley.com is a great company and they have a section called 1/4X20 Jig & Fixture parts in their catalog
http://www.rockler.com is another with a good selection of jig knobs. They even have a ratchet knob for tight spaces
Lot of door pulls will have a 1/4X20 bolt attached or you can epoxy one into it. The designs are endless.
You have a number of the bigger woodworking stores in your area, give them a try. Their prices are usually cheaper and they are use to discounting in lots of 5 to 10 pieces.
Hope it helps.
PEACE !! /wwwthreads_images/icons/smile.gif
w
#11 ·
I hate to be the kill joy here, but has anyone considered what those exposed heads will do to your head?
I don't know about you, but I bang my head on sh*t on a regular basis, and the last thing I need is something to rip skin when I come in contact with it...
#12 ·
You are EXACTLY correct TR. I'm already on it. I wound up settling on a set of these:
http://www.mcmaster.com/param/asp/psearch.asp?FAM=thumb&FT_101=101&FT_113=11121&FT_110=11106
Low profile, only stick up about 1/4" from panel which is slightly inset between the bars, so the total exposed area is only about 1/8", if that. The knurled plastic head doesn't have any "sharp" edges. The rest of the mounting hardware is all button-head inset allen heads, so no problems there.
#13 ·
I didn't want to be a pain in the a$$, and people take stuff I say the wrong way a lot of the time...
I have ENOUGH holes in my head! /wwwthreads_images/icons/mad.gif
And I know me, if you can bang your head into it, I'll be the one to do it! /wwwthreads_images/icons/blush.gif
#14 ·
No offense taken, you brought up a valid design point. I would MUCH rather somebody throw a flag like that up early in the game than about 5 minutes after I lay open my flat, sloping fer-head on a big honking chunk of flying metal. Besides, I look at you, Dirt Dog, Leve, Caver Dave, and the rest of the crew around here as my sanity/finger check on this kind of stuff.
Another important point, this console is made of 16 gauge steel. In the event of an accident it could easily become a guillotine, if not properly secured. Though the HEADS are plastic, the bodies are stainless hardware. Also as previously mentioned this is all secured to the cage via angle iron which is welded to the spreaders (nuts are tack welded/captured to the back of the angle iron).
P.S. Today it's getting painted, the wiring is starting, and I have the digital camera. Pictures and write-up soon to follow.
