I posted a while back about having a bushing stuck in my crank, posted some pictures, etc. Anyway I finally got it out after too many hours. In the process I slightly (maybe a bit more than slightly, but not tremensously) gouged the crank.
This is on a 1972 4 bolt main.
Is the crank shot?
Mark F
1986 CJ7, Chevy 350, D44/D30, more to come shortly
Cant tell you for sure, but get some emery cloth and polish it up to remove any sharp edges.It's a gamble, but it may work out just fine.The problem I forsee is a piece of grit getting stuck in the gouge and reacking havic on the bearings giving way to precius oil pressure..
It's as close to a 1ton as it can get and still be a jeep!!! Gotta love it!!
let me clarify the gouges are on the rear face where the flywheel mounts. One gouge is on the face, the other is on the surface where a pilot bushing would go. I am not useing a pilot bushing, cause I'm installing an auto 700r4.
I'm concerned about balance.
Mark F
No problem then, it cant knock it out of balace with a small gouge.Now you go to drilling and taking out lots of material then yeah!!! I personally wouldnt worry about it, but I'm not a machinist...
Official Historian
You're talking about just a little material very close to the center of rotation. That should not make a bit of difference.
Great thanks for all of the help. I feel better now the 700r4 is now in, just need to run my lines and put the D300 and I'm back in business.
