1 - 8 of 8 Posts
I went out of town last week, and when I got back I was trying to start my Jeep. The carb's always kinda slow getting it started if it hasn't been started in a while so I have to try it several times. The first couple times I tried it, it was turning over but it sounded weak. Then I tried it and got a clicking noise. Now I get the clicking noise sometimes and sometimes I don't get anything. The battery went dead on me once, but I charged it and I think it is ok since the clock is running and the buzzer sounds when I turn the switch on. I've tried jumping it off and that doesn't work either. I changed the solinoid in between the battery and the starter on the firewall and that didn't do anything. I roll started it and it ran fine. Does anybody know what might be wrong? I need to get this thing going today. Thanks, Andy
If you jump the vehicl and it dosen't start then there is a huge load placed on the charging vehicle. That's not good... I'd check in this order.
1. Grounds.
2. Cables.
3. Battery (Charrge, pull and check it out on a load tester).
My guess is it's a combination of two problems... a bad battery and cables/ground.
I got the battery checked and it is good. The ground cable going from the battery to the block is tight. I guess I'll try some new cables. If that doesn't work is there any chance it might be the starter?
Thanks, Andy
Official Historian
LEVE nails another one with the first suggestion.
Good call LEVE. Been there done that. My buddy spent 5 hrs pulling hair on his before he put his tail between his legs and came to me. He is a pretty good wrench too. I figured I was in for the worse, but I started with the simple things first. Man was he PISSED when after 5 min. I found out it was a bad ground at the block.
About a bizillion years ago I was in the TV Repair business... I charged a lady $^0 to replace a resistor on her TV... in fact I told her to wait and I'd be back in a few minutes with it fixed. She was really upset I charged her so much money for the repair. I tolt her:
1. It was only about $0.25 for the resistor,
2. And $59.75 to know which resistor to change.
3. And pointed to the "Estimate" sign which was quoted $60 (This would come off the repair if the customer chose to complete the repair.)
4. And pointed out she'd saved a quarter and waited only 15 minutes....
It didn't help.. she was still upset.
I had a lot to learn about the difference between being honest and salesmanship. I still prefer being honest and letting the concequences fall where they may over salesmanship...
1 - 8 of 8 Posts
