Guest
·i am doing a ground up rebuild of my 67 cj-5 i recently picked up a dana 44 front from a 78 fsj cherokee what i am wondering is what type of extended break lines should i use? i will be shortening the axle to orig specs (or close). i am also planning on using the original d-44 with 2-pc axles, i was just going to upgrade breaks and include a lock right. this will be using a skyjacker 4" lift, and 3/4"lift shackles. a 231 buick v-6, turbo 350 trans and d-18
tcase. i would like to run 35" tires. if any one has any comments or tips expecialy about the running gear please post them as i am new to this type of work, and i am sure there are issues i havn't even considered yet. this is a great board and you guys are a great help to all of us less experinced folks.
