Guest
·I am building a CJ-7 to be a good rock crawler. This a the setup, 360, 727, D-300, Dana 60 front w/ 4.56 gears, 14 bolt Full floater w/ 4.56 gears. Now I know I am going to go with a SOA but I am trying to deciede if I should use stock springs or a set of 2 1/2" springs. I am wanting to clock the transfer case so that I can use a flat skid plate, but if I do this with the 2 1/2" spring being SOA will I need CV joint on both the front and rear drive shaft??
I know that I can probably get away with not using them if I use the stock springs but I am unsure about the 2 1/2" springs.
Anyone have any input???
Peanut
Peanut
