I'm planning to buy a 5 BFG A/T 35" tires with rims cheap, but the rims are 6 lug pattern. I can convert my front from 5 to 6 no problem, but the rear either I get 6 lug axle shaft get it cut and repline or get an adaptor. Adapter maybe cheaper and I can always goback to 5 lug if I need to.
The rims that I have on now are rusty I need to replace them. The rims that come with the tire I'm planning to buy are "6 lugs Steel Black Rockcrawler". I know I should stay on 5 lugs and they are common. And also I need to put spacer on my rear anyway about 62" the front is 65".
For the cost of a spacer and whatever 6 lug conversion you are planning on, you can buy 4 new steel black rockcrawler rims (they're usually around $40-$50 ea.). Use the wheel offset to increase your track width - a shallower offset in the rear, a deeper one in the front. As long as you stay with about 3" of difference, you'll be OK.
If money is no concern (it usually is for me!), then do the conversion.
The difference in the width of your axles is supposed to be that wayit is for turning and straight line tracking
Related Threads
Off Roading Forums
1.4M posts
22.4K members
Since 1999
A forum community dedicated to all off road vehicle owners and enthusiasts. Come join the discussion about performance, engine swaps, modifications, classifieds, troubleshooting, maintenance, and more!
