My the mistakes we make (need some info)
633 Views 11 Replies 2 Participants Last post by  **DONOTDELETE**
Well the CJ started yesterday, but alas on final assembly I noticed that I no longer have the air-cleaner retension stud or attachment or whatver you call that thing that goes from the carb through the center of the air box. Anybody know where to start looking for a replacement? or of another way to keep the damn thing on? Would parts stores have these and if so under what name? My discription only gets me puzzeled looks and strange glances.
1 - 12 of 12 Posts
You can pick one of those up at any parts store. Usually they sell them in the box with new air cleaner assemblies. I think they are just called "air cleaner studs". You may have to shorten it though. The one I got was way too long. I just took a hacksaw to it and cut it to size. No problems..
Carl, Tampa, FL, 74 CJ-5
If a Jeep can't take you there, Think twice about going..
Some threaded rod in the proper size will work...thats all that they really are.
'79 CJ-7
The roblem I have is I am missing the cross piece also that the rod would thread into.
How about the junkyard. You don't say what carb you need it for, but an Eagle might be a source.
Sorry its for a carter BBD, Junk yards are few and far between here, I have called a few with no luck.
I sure wish this would have presented itself Friday. I spent Saturday morning getting York A/C brackets from an Eagle and saw several of the parts you need. Could have pulled one and sent it to you. If I go that way anytime soon I will send you a private message to see if you still need it.
I think I have what you are looking for, I will know for sure this weekend, do you still need it?
Dan
If DCMSU doesn't have one, I should. I have two carters in my supply shed. I'd be glad to toss one of those studs your way.
if pep boys and checkers don't have one then call the dealer. i rarely use the dealer but this would not be a big ticket item. i bet the dealer will either have one in stock or can order. it must be just like on my 87yj. i have taken it off a few times to rebuild carb. curved spring steel that you have to pry open to take off carb with a short threaded stem attached that air filter canister bolts to!
good luck parts chasing!
steve
I am going to make one last try today on locating the part, If I have no luck I will take someone up on sending me one. I'll let you know how it goes. Thanks for all the response, this board is a real saver.
1 - 12 of 12 Posts
