Also have rear seat out of CJ-5, stock, fixed postition, decent shape.
CJ Grill
CJ Manual Steering Box, pitman arm, and shaft
CJ Dash Pad - little rusty on backside. Had been painted black, paint wearing off, originally blue
YJ - 2 Front Original Springs - minus 1 bushing
CJ Dana 30 6-bolt spindle w/2 nuts
CJ Dana 30 Warn Premium Locking hub (1)
CJ Dana 30 Warn Premium Locking hub missing some internals
NEw Warrior Products 3" Spring Perch -New- out of package but never used
YJ Stock Spare Tire Stop
CJ Stock horn (worked when I took it off)
CJ Stock windshield washer resevoir with pump (not sure if pump works)
CJ Stock leaf springs
Misc. Spring plates and U-bolts
CJ Driver Side Seat Brackets
CJ(?) Radiator overflow bottle
CJ front slip yoke only with u-joint
(1) lap belt (stock?)
CJ Driver Side mirror arm, bracket, cracked glass
CJ-5 Tranny Cover for floorboard
Samurai rear axle stock bumpstops
2 Dana 30 Axles Complete - 1 set of Pro Comp hubs(shafts may already be sold, as well as 6 bolt caliper brackets and calipers let me know if you want them, and I'll keep you informed)
AMC20 1 piece rearend 3.54 gears (shafts may be sold, let me know if you want them and I'll keep you informed)
AMC20 Stock rearend 3.54 gears (may be sold, again, if you want anything from this assembly, let me know and I'll keep you informed)
Post here or e-mail me [email protected] if you want something. Later, Casey
Click for info: "1st Annual Anniversary Trail Ride Weekend" in Gulf Breeze, Florida!
http://www.extremetrails.com
Are you willing top pull the Hubs and bearings, locking hubs and disk brakes off of the D30s?
I need four complete sets.
thanks
87YJ
Here we go again. Done once and now doing it right.
Casey
I do not need the calipers or the brackets. I would like the Hubs and bearings, rotors and lock out hubs. If you only have one set OK and if you don't have rotors Or locking hubs OK also. I need the hubs that fit on the spindles, the rest is kind of easy to come by.
87YJ
