Re: My Jeep is still \'a shakin\' (need tech help)
Based on your description, I'd say it was the clutch as well, but since you covered all those bases it can't be that. I had a '78 Scout II (well, still do, minus the axles /wwwthreads_images/icons/smile.gif) that did the EXACT same thing you describe, and it was the clutch. BTW, NEW pressureplate I hope? I've had chowderheads replace the clutch and bearing but not the pressure plate, kinda defeats the purpose.
Check your tranny and engine mounts. Try to jack on the tranny and engine on different points and see if one is loose or broken. When it warms up, it would soften the mounts and allow them to move more, versus when they're cold and stiff. Other than that I can't imagine what it could be. The cold shouldn't affect the engine in the morning as far as driveability is concerned.
I hope this helps, sucks having a problem and not being able to correct it.
JEEPN
'81 CJ-8 Scrambled!
JEEPN
'81 CJ-8 Scrambled!
