Guest
·Ok 87 YJ, 258. I have oil and white smoke coming out of my Crankcase Breather hose. I have replaced the valve cover thinking maybe my baffles were all messed up and they were the front one was sucking up against the PCV valve, but even the new, stock Mopar valve cover didnt fix the problem. What else should I check? I'm checking the compression tomorrow, but the engine only has about 30,000 on a comeplete rebuild. If my compression test comes out OK then where should I go next? Oh yeah and my PCV valve is definitely working it has suction, but I don't know how much it really needs..it does pull your finger when you put it over it. I'm in college and this is my first jeep and I don't have the money for an engine swap or a complete rebuild...I hope to god it isn't that serious or I may never own a jeep again...
thanks in advance
thanks in advance
