1 - 13 of 13 Posts
A while back I used a website which contained all the MPI computer codes. Now I cannot find it in my bookmarks, nor a search on this list. Anyone still have the link??
TIA!!!!!!!
Scott
'85 CJ7______T.H.O.R.
/wwwthreads_images/icons/wink.gif"To Her, OutRageous"
/wwwthreads_images/icons/laugh.gif"Tally-Ho Over the Rocks"
Sorry, I guess I should have included more info. This is for the Hesco MPI kit, I belive it is a 94 YJ computer.
Thanks!!
Scott
MPI codes (Again).
Bump.
I remember someone had them on a web site about 8mos back.
TIA!!!!
Scott
/wwwthreads_images/icons/laugh.gif"To Have Off Road"
Re: MPI codes (Again).
Scott,
I'm just curious here (a seeker of knowledge)........if the Howell is using the existing YJ computer........what different codes do you expect to get?......or does the Howell have it's own seperate cpu and it's own set of codes?
GeeAea
I am sorry, I am not using the Howell, I am using the Mopar. The Mopar is a Modified 94 YJ Injection system.
Maybe I was not clear, I ment M.F.I.
Thx!!
Scott
Here ya go..
Computer trouble codes
1991 on
Code Probable cause
11 Ignition
12 Battery disconnected in last 50 cycles
13 Manifold Absolute Pressure (MAP) sensor vacuum
14 Manifold Absolute Pressure (MAP) sensor electrical
15 Speed sensor or circuit
17 Engine running too cool
21 Oxygen sensor or circuit
22 Coolant temperature sensor or circuit
23 Air charge temperature
24 Throttle Position Sensor (TPS) sensor or circuit
25 Automatic Idle Speed (Al S) control
27 Fuel injector control
33 Air conditioning clutch relay
34 Speed control solenoid driver
35 Fan control relay
41 Alternator field
42 Automatic shutdown relay
43 Ignition coil Number 1-3 primary circuit; peak primary circuit current isn't reached with maximum dwell time
44 Battery temperature sensor
45 Overdrive solenoid - open or shorted condition detected in overdrive
46 Battery over voltage
47 Battery under voltage
51 Oxygen sensor - lean condition indicated
52 Additive adaptive memory at lean limit.
36-63
Fuel Injection Diagnostic Manual
1991 on (continued)
Code Probable cause
52 Oxygen sensor - rich condition indicated
53 Internal engine controller fault
54 Crankshaft signal sync pick-up signal - no fuel sync signal during crankshaft rotation
54 No cam sync signal at PCM; open or shorted condition in cam sync signal circuit
55 End of self-diagnostic display
62 Emissions Maintenance Reminder (EM R) mileage accumulator
63 Controller failure EEPROM write denied
76 Fuel pump resistor bypass relay
JAF
Thanks alot Jaffer!!
That took some time typing in, I really appreciate it. I will put this on MY website (when I am finished working on Thor!)
-S
Scott
Here is my stupid question to add to this discussion: How do you get the codes to display for the YJ. I have done it with the 3 ignition switch method for a TJ and gotten it to work, but got nothing with my YJ. Is there another trick, or does my wireing suck?
It's ALL good!
Discussion Starter · #12 ·
I am going to guess, try 5 times on (on-off-on-off-on-off-on-off-on)that is what the MPI is and it is off a '94 YJ.
Scott
What year YJ do you have? If you are trying to get codes out of an '88, there are none to get! Mopar EFI is capable of displaying codes, but you must hook up the check engine light first. Hope this helps!
1 - 13 of 13 Posts
