Guest
·Has anyone installed bearings on Moser 1-piece axles? I have a Model 20 rearend that had Moser axles installed by Palmer's 4x4 in Everett, WA. I had them rebuild the rearend last September and the bearings went bad this month. I e-mailed Moser Engineering and received a replay from Robert Moser. He sent me the instructions for installing the axles. Reviewing the instructions I noticed that the bearings where installed wrong, (race in first so when you pull out axles the races are left in the housing). Do the outer races hold the bearing into the housing? The instructions also are not precise in torqing the bearings? This last weekend I bought all new parts, bearings, press rings, inner/outer seals, bearing spacers. I pressed the bearings with the larger lip in inner bearing race facing to the inside, (axle splines). The outer race was fitted to .040 sticking out of housing flange. The press ring was pressed against the inner bearing. The bearing spacer ring was fitted snugg against the inner bearing when the axle was bolted in. If the spacer ring was not up snugg to the inner bearing, there was some slop in axle, it would move back and forth in housing about a 1/16th. After installing the bearings on Saturday, as I was driving to work today the driver's side axle came out about two inches and caught on fire. I tore both axles apart tonight and the bearings are both shot.
My question is has anyone installed bearings on these axles and give me some pointers. Hopefully step by step instructions that are more precise then Moser's? I just blew over $100 in parts and don't want to do it again.
Thanks for taking the time to help me out on this.
Ken Christensen
[email protected]
Ken Christensen
[email protected]
