You have the plain old Motorcraft distributor and DuraSpark module. Same stuff we have been talking about.
You already have the large cap, so, a good cap and rotor puts your distributor in line.
The TFI coil and coil connector is a direct replacement for yours, and will improve usable spark energy by about 1-1/2 times all through the RPM range.
You are also one step away from the MSD 6 series upgrade, that will give you Capacitive Discharge Ignition, and Multiple Spark Discharge,.... (CDI & MSD)
This module will increase your usable spark energy by 100 to 1,000% on all things that count. The unit is about $135 for the base model to about $250 for the bruiser.
Nothing else to buy, works with your stock everything.
If you live in a non-emissions state, you can even wire it so you can use your DuraSpark as a back up incase the MSD unit fails in the field.
Let me know, and I'll give details.
