Ok - this is my first time to post hope you guys can help. I have a 88 Samurai with 1.3. I have a miss that happens everynow and then. I have taken it to the mechanic cause I dont have time to troubleshoot the problem. The mechanic said that it was a bad distributor cap (which I think is bull - cause I just tuned it up). After he charged me $151.00 for changing the plugs and distributor cap, thats when I found the time to troubleshoot the problem. Not to mention that the miss is still present!!! I have changed the Ignition Coil, O2 Sensor, Fuel Filter (I cut the old one in two & it was very clean), wires, rotor, cap, re-gapped the plugs, and I have just ordered the vent tube for the carb. The miss is strange it does it when under a load like going up a hill or down shifting to pass a car (usually a Jeep, LOL)! The miss keeps on until I pull over and let the thing die - restart it and it is good to go. I have noticed that after this the Tach reads about 1.5 at idle. I have also thought that it could be the ECU getting to hot cause the Zooks heater REALLY works - Has anybody found a similar problem with a ECU like this before. Hopefully the Vent tube will correct this problem or maybe your guys in the Zook Frontier can shed some light here - any help is greatly appreciated!
