1 - 12 of 12 Posts
Any thoughts about the fab fest? Projects, installs, modifications, trail rides, etc... Any ideas or thoughts? I would hate to have everyone travel there and we just stand around bored, looking at each other's zuks and scratching our butts! Have we nailed down a date and location yet?
Capn_Crunch - Want to gather your parts for your SPOA and do it there? I can bring my MIG welder, chop saw, air tools and 4-1/2" grinders. Lav25 has a MIG welder, plasma cutter and a portable compressor. I could trailer my Samurai and load the back of my Suburban with tools and parts.
Tim Martin
87' Samurai/1.6L/dual 40mm Mikunis/header/2" exhaust/MSD 6AL/5.5" SPOA/1" shackle lift/CJ-5/Sami springs/31" High-Tecs/roll cage, bumpers & pumpkin caps in progress...
Tim,
I was thinking the 18th or 19th of August or sooner if you guys want.I would like to have mine done before Zukimelt. I'm open to any days that you guys would like. I am waiting for my OME springs to get here for my own SPOA,and would like help with the conversion. The problem with August is it's too damned hot here to work on anything without an airconditioned garage!
ROB
Hey Rob,
You'll need it done before August for Zookimelt. Are you driving out? I going. I'm not trailering mine; I'm gonna take a 4 day weekend and drive out. (could be a dumb thing). It'd be cool to convoy out.
Pauly
Have you'all picked a location for the Fab Fest yet? I see the date is still in question. Anytime is fine, though I agree with Robzuk, its usually very toasty in Aug.
My sammurai is coming along nicely. It is currently on jack stands. I have installed the rear sammi springs up front using the RRO kit and CJ5 springs in the rear with the CSC kit. I wonder if I can lift the vehicle high enough to fit the axles back under it, HEHEHE.
I should finish the front axle rebuild today w/ 4.62's, just need to finish welding the spring perch supports (connecting upper and lower..Spoa already welded). If it wasn't for the rain, I'd probably install it today. Not looking forward to removing the stock pitman arm though. I hear it is a PITA. Also I ordered a hybrid rear axle with the works (lower shock mounts, pumpkin caps etc.) should be here within a week.
All I need for the engine swap is to decide which clutch to use between the 1.6 and Tracker 5sp.
"Reality goes on without me!"
Whazoo - Let me know when you fire that engine up? Damn, the way you are flying with your build up, that credit card and check book has to be on fire!
Tim Martin
With five or six of us there we could whip out some SPOA lifts! Have two people removing axles as fast as you could weld the spring perches and shock mounts on. I have never done a ring and pinion swap on an axle and if I don't already have them done I could use some help there. I have done VW transaxles, but they are a piece of cake.
As far as the date, the end of August is fine. Just make sure it is not the weekend before the kids start back to school.
Tim Martin
I don't want to wait til the end of August for my SPOA. Hopefully I can roll down your way within the next month and put it on then. I have to wait til next week to order it though. My money's still tied up in bad investments...
Pick an earlier date if you want, like I said I'd like to have the SPOA done before Zukimelt. I'm towing the Samurai out on a trailer. If you guys want to caravan out there that's ok by me. That way if we have a problem we can hopefully fix it.R/T wanted to meet up with me somewhere on the other side of the mountains as well.
ROB
Good luck with your FAB FEST,hope you have as much fun as I did with mine ,minus the rain,RR
THANK GOD FOR VETERANS AND SUZUKIS-BOTH KEEP YOU FREE. FOUNDER;INDIANA SUZUKI EMERGENCY RESPONSE TEAM
Today I gave lav25 a hand installing the front half of his rollcage. Looks really good. It has inspired me to work on my cage a little more. I must finish my front bumper first because right now I am driving around without one and it is only a matter of time before I get pulled over by a trooper and given an inspection ticket. Glad to hear that the Fab Fest was a success!
Tim Martin
1 - 12 of 12 Posts
