matter of life or death for my jeepster
705 views 6 replies 2 participants last post by  **DONOTDELETE**
Hello, I was wondering if I could get a suggestion or
two about a problem I have, I would like to know if
anyone else had a similiar one. I rebuilt my engine
for my 70 commando convertible, (225 v6) and after
installing the braided seal for my crankshaft main
bearing, I torqued everything down to spec and now
my engine will hardly turn over! When I energize
my solenoid on the starter, the engine will turn over
slowly (like 3 revolutions) and then drains the
battery. No matter what I do, it seems like that
seal is making the engine not want to turn. Ive tried
higher torque starter, better battery, i have spark,
compression, etc. Has anyone had a problem with this
braided seal?
Any ideas on how to get my beast to turn over fast
enough to fire?
please help me get my dream running! thanks.
Pull the sparkplugs and put a socket on the crankshaft pulley bolt and turn it by hand. It should rotate easily with moderate resistance from the valvetrain. Try this first so we can rule out engine drag. It may be electrical, such as incorrect timing or missing engine ground strap.
Chris
#3 ·
hello and thanks for the response!
I should have mentioned that after I first
installed the braided seal, with the engine on
the engine stand, I could barely turn the
crankshaft with a wrench (I mean it was hard!).
This is what first made me suspicious that the
seal was causing the engine to drag.
I checked the timing and it is close, as you
suggested and I also put a brand new ground stap
on.
I have truly run out of ideas, short of dropping
the pan and pulling the seal out. In which case
I don't know what to replace it with.
thank you.
#5 ·
Tight rope seal drag is common.
You didn't trim the ends close enough, it swelled too much when compressed.
Pull the pan and rear cap, trim it a little more, just a tad. When you take off the cap you'll see where it's too long, it'll stick right out. Rotate crank 1 or 2 turns to make sure that was the bind. If you pull the other caps, do it only one at a time, then retorque, else you distort the crank.
Lightly lube the shaft where it touches the seal with graphite assy lube.
Forcing it to start now will only burn the seal from heat, failing soon..
If you have to pull the upper half out, use a Sneaky Pete, available at parts houses. $6.00?
#7 ·
Mine leaked from the start. I tore it down and replaced it with a 2 piece rubber one from Felpro. checkers got it for me. look on the back of your old bearings and make sure that you didn't accidently install the wrong sizes. a standard bearing in an undersize journal will make life miserable. Hope this helps.
Lenny in Colorado Springs
67 Jeepster 225 3 speed(building me a T18 now!!)
