manual trans leaking
1115 Views 1 Reply 0 Participants Last post by  **DONOTDELETE**
my son's newly acquired 94 ranger, 3.0 liter, 5 speed manual, 77,000 miles, is leaking trans fluid at the seam between main trans body and the extension housing, sure doesn't seem like its leaking at shaft output. My question is how easy is it to remove drive shaft and extension houseing with tranny in truck?
Haynes is useless.
thanks
Not bad at all. Drain the tranny, pull the rear shaft, pull the output yoke, and unbolt the extension housing. The two bolts on top shouldn't be hard to get to.
To remove the rear flange or yoke will be a bit of a task, but if you use a long breaker bar the nut should come off without too much grunting.
Just make sure you mark your driveshaft so you put it back on exactly the way it was before. If you install it out of phase, you'll experience some driveline vibration.
