<image src="http://tellico.off-road.com/wwwthreads_uploads/1220726-linkquestion.bmp">
Please pretend the dif is centered and the wishbone is simetrical.
Ok so I can use my homeade joints for points 2 and 3.
and use heim joints like the ones on the above suggested page for the rest 3/4" for all thread size. 5/8" (bolt size) on points 5 and 7. and 3/4" (bolt size) on points 1 and 4. The only acception is point 6 where I want something bigger like a 1 1/4 or so, right?
Now on anlgeing the links. I will ask these questions from the point of view from behind the truck like the pic is drawn from. So if I understand your last post I should mount the lower links in a way that the frame mounts could be on the bottom of the rails and widen a little before connecting to the axle? The wishbone then would then mount to the frame on an internal crossmsmber and to the axle in the center top of the 3rd? As the relation of points 1234 do they need to be in the same horizontal plane ro ofset like in the pic or what?
Now question while point of view on side of the truck.
These questions deal with length of links and horizontal angles. As I understand it the bottom ones are longer, depending on like you said wheelbase. So this is a kind of "it depends" kind of issue as far as length goes. But I want them to be long enough to be somewhat horizontal in relation to the frame right? Now as far as the leght of the wishbone structure goes is there a % it should be in relation to the length of the lower links? I only ask because I can put the crossmember in at whatever distance I need it to be to achieve stability.
I know this is a lot
, thanks a million. This will be so much more fun to do myself than buying a kit!
