Okay, I finally got around to pulling the check valve out of my master cylinder for the disc brake conversion, but I can't find it. I have the master cylinder apart and there's no rubber valve, ball or anything in, around or under the outlet for the front brakes. I didn't actually pull the seat as suggested in a prior post, but I can see right through it and can poke a rod through it with no obstruction. My guess is that I don't have a check valve to remove (no wonder my drums never worked right) but thought I'd check with you guys first. Any suggestions? Thanks.
'66 Jeepster Commando - 4.1L V6, TH400, 4" lift
'96 Jeep Grand Cherokee
'75 Yamaha DT400B
'75 Yamaha DT400B
