/wwwthreads_images/icons/wink.gif I am sticking to Toys, just wondering about the advantages of somehow making a Zuki transfer case fit in with a Toy case to get the high range reduction.
I did my math based simply on reverse calculations of what would be needed to make stock 4.10 gears "equal" 4.88 axle gears and that wouyld require a high range of 1.19:1
Even on the rather low comparison of 1.19:1, using 5.89 Toyota axle gears would yield an effective axle gearing of 7.01:1 - and that is pretty amazing /wwwthreads_images/icons/smile.gif
My basic idea would be to figure out how to use a Toy transfer case and a Zuki transfer case as a double setup.
Assuming a Toy case has a 1:1 high, 2.28:1 low, and the Zuki has a 1.4:1 high and a 2.36:1 low range, with a Toy 3.93 first gear and 4.88 axle gears:
-You get a high range crawl ratio of 26.85 (effectively the same as a normal Toy running 6.83 axle gears) 3.93*1.4*4.88=26.85
-You get a single Toy low range of 61.22 3.93*2.28*1.4*4.88
-You get a single Zuki low range of 45.26 3.93*2.36*4.88
-You get a low-low range of 103.2 3.93*2.28*2.36*4.88
-Add a Toy 4.7 gear set and get 212.72 /wwwthreads_images/icons/smile.gif
Anyway, just having fun running the numbers /wwwthreads_images/icons/smile.gif
